What is hooked to your exhaust manifold?Bump from the dead. 2004 round nose. Wet jet pipe broke so put the stock exhaust back on. Can't seem to figure out the water routing. ADA head also installed.
Bulkhead to nipple on the pipe.
2 connections off head to over board. With a small T in one to feed water through 1/8 line to pipe.
No water coming out if pissers. Did not change manifold gasket that was used from the wet jet manifold. I'm sure they are the same tho?
Sent from my SM-G955W using Tapatalk
