cycojon
addicted to my superjet
- riverside ca
like the title says,
how do you tell them apart, any advantages to haveing one over the other?
The am's supposedly have better internal fuel circuitry.
Looking at model # is one way to tell. Another is to look at the fittings on the pump block. Removable brass fittings = am; while non-removable tubing fittings = OEM.
What are the model #?
I use a 60 main jet (because the body is bigger). You can put it inside the return line and clamp down on the outside with a hose clamp.
