yamabro
GP Performance / Patterson Powersports
- Dickson, Tn.
Part 2 to the "Free, Trim Cable Thru Hull Seal"
http://x-h2o.com/index.php?threads/free-trim-cable-thru-hull-seal.167997/
Utilizing the temp sensor wiring harness to supply power to your single or dual bilge pumps.
NOTE: Make sure to disconnect battery before doing this conversion
BENEFITS:
-Keeps the E-box sealed to OEM spec so the internals of the E-box does not get water intrusion
-You NO longer have to fool around with separate eyelet connectors when connecting or disconnecting the battery. Therefore keeping a better and dedicated electrical connection for the + Positive, and -Negative cables/lugs coming off of the battery.
You will need:
1. Cut the red wire in half and connect the bullet connectors to make the "Y" jumper as pictured.
Connect the Pink (+Pos) and Black (-Neg) in line with your switch and bilge pumps with what connectors you choose.
BENEFITS:
You will need:
- OEM Yamaha temp sensor wiring harness
- Small piece of Red wire @ 5" (no less), *to make "Y" in pic
- (1) Male bullet connector and (2) Female bullet connectors, *to make "Y" in pic
- Open up the E-box and disconnect the +Pos bullet connector coming off of the +Pos battery cable (connected to the start relay)
- Connect the "Y" jumper to the +Pos battery cable end
- Then reconnect the +Pos red wire to the "Y" jumper (that provides power to your electronics)
- Connect the pink wire to the other end of the "Y" jumper
- Connect -Neg black wire back to its original OEM bullet connector
