EME. But takes some modification for the Yamaha driveline to work.
Believe Malone said this would not work, Tricky shoehorned in a 144/148 Skat Mag Pump in his.
Personally I like the Kawi Pump setup!!!!!
this question is so flaud mainly because no hull should even be considered an after market freestyle hull if is "based" off anything. Any decent hull should be modified, length, width, chimes, pump tunnel length and width, bond line etc......so there shouldnt be anything kawi or yamaha remaining, otherwise its just a modified stock hull, which anyone with an auto zone fiberglass kit and a grinder can accomplish for a lot cheaper.
why not "hydrospace" based....
So the bob isn't an aftermarket hull? Wasn't that "based" off a 300sx?
gen 1 yes
anything after that not even the slightest.
you could say that , the front bottom of the gen 2 to hurricanes are like eme'sgen 1 yes
Was the bob gen 2 made from the gen 1?
Wasnt the Gen 2 bob pretty similar to the Gen 1 except instead of having the Gen 1 hood look, and fit exactly like a 300sx hood, they made it into a "lid"?
