Vumad
Super Hero, with a cape!
- St. Pete, FL
Does anyone know if there is a place to get offset dampers or a blank that I can drill my own hole in. A friend is running a mismatch pipe/manifold on a x2. I was able to line up everything to some degree but the mount is not being used properly. The bolt is about 50% off center so I don't think I can make a damper set centered work. Any thoughts?
Here is a picture of how I have it bolted together now for mockup. I think it could be okay with the beefy washers but the 12mm hex is in a 20mm hole. There is already vibration damage from before I got a hold of it, the mount wasn't being used at all. all the rest of the alignment and spacing for the exhaust is pretty much perfect.
