The oil we run is partially personal preference and partially based on our experiences and our peers experiences. I am of the belief (possibly erroneously) that there are lots of good oils for us to run and some engines obviously warrant higher tier oils. I was hoping we could create a list of what oils we are running, mix ratio, price of the oil, engines we are running it in, and a description of its smell, if any. Any additional tertiary information would also be appreciated.
The thread is not to debate oils necessarily. Healthy debate is good however these threads can sometimes devolve into bash fests. Think of it more like the carb settings thread where we are simply sharing our personal setups and reasoning.
I will start it off with the oil I am using.
Mystik PWC fully synthetic: https://www.academy.com/shop/pdp/mystik®-jt-4-synthetic-2-cycle-personal-watercraft-engine-oil
Price: 24.99 Gal
Engines ran in: Limited superjet, Venture 1100, SX-650
Premix ratio: 32:1
Color: Purple
Smell: Mild, yamalube like.
Consistency: Thin
Gallons used: 3
Notes: I chose this oil because I got a great deal on it (ten gallons for fifty bucks). I was already using the semi synthetic version with good results since it is readily available in my area. From my research when deciding on this oil I discovered it is made by Citgo, the same people that make yamalube for yamaha. Additionally The Sea and Snow version is reportedly the same as Yamalube 2w according to here. http://greenhulk.net/forums/showthread.php?t=247303
Price: 24.99 Gal
Premix ratio: 32:1
Color: Purple
Consistency: Thin
Gallons used: 3
