ok so i think i may have just made a not so cheap paper weight. i put my cases together and i thought i had all the crank pins aligned. well i didnt and here is what happen. anyone know if this is fixable or am i screwed? :banghead:
they are already ported. so not even if i push the dowell back threw and epoxy it back in there? they use epoxy when they port cases. if i remember right people use to epoxy the cases to fit stroker cranks.
Yes, just grind out the area where the dowel tried to punch through, use a punch and get the pin back in place, then be very clean with a patch of JB weld and sand smooth and be careful to line up the pins and put it back together.
