Other Opinions requested - single or dual carb for 62T setup and why please.
95FX1
brrrrraaaaaappppppp
First thanx for the help all....
just wanted to see what way i should go. I just put 62T bottom on my 61Xtop
currently i have a set of 38s setup on my ski...stock intake
but I also have a set of 44s i want to upgrade to but i only have the stock intake so i will need to
get the 44/46 intake if i go that way...
the single intake for a 44/46 cost about the same as the dual...and i have a good 46 carb i could throw on..
so what way would you go if you had to get an intake anyway to upgrade..........what one?
thanx again all
Buckwild12
I'm moved by DASA power!
Ive been told by others that duals always make more power than a single due to the turbulence caused by the alternating cylinders drawing in fuel. I have always had dual or triple carb motors in my time with jet skis so I cant tell you how a single is different. But I can tell you that my sources are all very credible and have that experience. I went with a Dasa billet Dual intake on my new motor along with Dual 46mm Blackjacks. They look awesome, I hope they perform as good as they look.
