Freestyle Optimum Intake to pump size?
Impeller pitch and nozzle size?
I am running an oem 155 stator and wear ring. I blueprinted the pump a bit but more grinding was actually done to fit my tbm pump stuffer. This gave me a big hub so I got a e-75 skat swirl. Use my superjet drive shaft and rear bearing. I run a skat adj gp1300 reduction nozzle, gp1100 trim ring and an fx140 turn nozzle.
D-Roc
I forgot!
Yup my buddy did 155 in a blaster and 1100 triple. It did have some hookup issues if I remember correctly it was cavitation down low where we need it. If your going to do it, you gotta do it right. I tried to account for everything to make sure that didn't happen with my ski.
Hijacking thread, guys, what about a intake duct for 148mm pump...
Which one to get??? It doesnt make sense to run even 148 with the oem std intake duct.
Gera
D-Roc
I forgot!
148 with the correct pump shoe is not going to be starving IMO. In a perfect world you could use the volume of the 144 intake that Yamaha engineers designed and create a ratio. Plug in the new pump size to see how much volume you would need to feed the pump. As according to Yamaha.
I feel that my intake is too big for the pitch I am running in my 155 but it is only noticeable at full speed.
D-roc, it is a newer style SJ which seems to have a larger intake area...
My question is about a intake duct. The plastic one looks smaller than 144 and the aluminum looks not larger.
What you recomend??
Thanks
Gera
D-Roc
I forgot!
I think if your plastic or aluminum pump shoe is smaller diameter than whatever size pump you use, there will be starvation issue regardless of the hull intake duct/area size. The aluminum one can at least be bored out to match a 148 and still retain its strength. I have not tried to open up a plastic pump shoe, I imagine it would be very weak.
You can do it with an OEM shoe, but it is skeletonized so you have to fill the voids with JB weld beforehand.
