My walls are reinforced with black fiberglass and floot is coated with some type of black resin pain, seems like the same stuff used to glue the fiberglass panels to the sides. Ill be pulling out the engine and i plan on paintin the hull off white or something similar. I dont want to use spray paint because that stuff comes off to easy if its sitting in water especially. Any suggestions on what paint would work well to use with a brush or a roller?
