dbrutherford
Parts Whore
- Fairmont, WV
I think we should have a best turf contest!
i don't use a templete for anything but the bottom where you stand.
depending on ski...
I use templates for all.
sides bottom, whatnot.. and depending on angles is where you start
so you can heat and stretch to make minimal seams.
as far as the turf tricks.. sand ski well and then sand back of turf...
60 grit.. nice and easy for scratches. then actone clean.
dont apply glue heavy either. let time to dry... NO DUSTY AREA...
will stick to glue and you be beat.
:Banane09:
I sat my turf outside in the sun and noticed it really softened up and is alot easier to bend, should i just work outside to keep this effect going or go get a heat gun?
My last question i think...
What do you guys do when you get to the top of the gunwales? I plan on doing the sides first and starting from the front and working my ways from bottom to top front to back. I cut my templates bigger just in case i was off somewhere. What should i do about the excess? im worried about the glue getting all over my paint and then me not even needing to turf there.
you just wait bro.
yours will be a work of art :sneaky:
Is that metal plate on the rear tray/boweye area stock on SXR's or did you make it? Is it bolted/epoxied/5200'ed down? Nice idea
Agreed! :fing02:But vitalikol is right, Pete is a great person and would give you the shirt off his back.
