mike b
- California
If you need those spacers my buddy @toddgrochowski has some from his eme. That would end your spacing issue
No worries man it's just little stuff that's the only issue I've had with the hull . The bed plate was hacked but I bought that used , what do u thing about me chopping a corner of the plate so I can move the motor back about another inchI talked with Levi, I didnt have this problem when I built that ski, but it had a mag setback pump so the shaft would have been 2" rearward. Sorry it isnt going together easy man.
Thank you manLooks really good and a great set up!!
Yeah dude I know Yamaha is way more ideal now , but I've already put a ton of time and effort in the motor and it's fresh . I bought a tiny tach /hour meter so I can know how many hrs I run it this summerI might run a stocker sxr in my Vengeance (mini sxr). It will be nice to be able to cruise and hit the boat wakes. I think you made a good choice going with your tuned motor set up.
ThanksSiliconeintakes.com for some hose reduces will be your cheapest option. Or the rad dudes exhaust hose is 2.5. the metal tube going thru tray is also 2.5.
