PHP intake manifold
JetManiac
Stoked
orlando
PHP
(PowerHouse Products) has designed what many (including us at JetManiac) feel is the best designed intake manifold for Yamaha twin carb motors. This is a state of the art freestyle intake manifold for 62t or 64x Yamaha cases, not a manifold designed for the needs of high RPM racing. We have installed and tested them on PHP, DASA, and JetManiac/Blue motors with great results.
This intake was designed specifically for freestyle performance. It features a shorter and better designed intake track shape for more freestyle low end performance. The manifold is a 3 piece design with a removable O-ringed billet carb base plate which makes removing and reinstalling carbs easier while preserving carb linkage alignment. The manifold itself is 2 piece for future compatibilty with longer crankcases cases in development at several companies. Only a longer speed plate will be required. Removable throttle cable bracket is included.
PHP manifold is designed to work best with VForce 3 reeds and cages, but will work with stock or other reeds/cages setups. Manifold inlet is a perfect flow fit to the larger sized VF3 reed stuffers.
PowerHouse Products (PHP) billet intake mani $449.95 sale 418.95
(Includes manifold, speed plate with orings, throttle cable bracket, and all SS hardware)
Mesa AZ
I'd really like to see a picture of the side that bolts up to the case. I want to compare with "another design." Is it able to be ported(grinded) to use no stuffer with the Vforce 3 reeds? Basically asking if there's enough material there to make the opening more square than oval...
N3vrSat1sfied
Military Member
Fort Worth, TX
So no 38s? Hmmm. I already have v force 3 reeds but I'm always searching for bottom end. Have your 735 engine. 10/16 hooker and about to put a 144 mag but I figured if a better intake could help them for the price I couldn't go wrong.
The mag pump will make a huge difference. Remove the fins from your reduction nozzle when you do it.
PHP
This manifold has always been a great value at $365., but JetManiac has teamed up with PHP to lower the cost for you. Last Fall, we commited to a higher volume run over the winter and some new manufacturing techniques to lower the cost.
As a result we are offering introductory pricing of only $299.90 !!!
PHP 3 piece intake manifold 365. Special 299.90
Hey man can u send me a pm I would like to buy one of these powerhouse php intakes and can’t figure out how to message you ! Thanks
