- Glenmoore pa
This is the 3rd 760 flywheel I’ve spun the ring gear on. Never had hydro lock issues, so idk why this keeps happening. Anyway, I figured I’d fix this one once and for all. I drilled and roll pinned the flywheel in two places 180 degrees apart then filed the roll pin flush. Do you think this will be enough to throw off the balance of the flywheel at all?
