pipe mounting with ada head???
I have a riva head and a factory type 9 dry pipe I'm tryin to find a mount can seem to find this riva mount. Does any one know well the ada mount work for me
Yes the ads mount will work on a Riva non girdled head for sure. I have one.
My setup is a riva non girdle head with an ada mount and a protec mach 2 pipe. I am running a modified half girdle on the carb side. When you use 'up' style pipes, the ads head, or any girdle head can have issues with clearance if the chamber is or large diameter.
