i know, i know, i know...but I can't find a solid answer so I'm posting.
Routing the cooling. I'm running a single line cooling setup on my 61x, limited bpipe, TL and solas 13/16.
I've got one cylinder-head outlet going to head pipe. Planning on running the other cylinder-head outlet to the pisser w/ a 4mm restrictor. Can I "T" in to the pisser line w/ the dump line from the head pipe-to-stinger line? I've got a standard FCV in the stinger line, but don't know if I need another pisser or just "T" into the existing pisser?
I've read lots of plumbing posts and see where lots of folks "T" both lines from head together and run to head-pipe. Is that so much flow to head pipe that the screws are nearly all shut? I'm not interested in 1/8 turn here and 1/8 turn there. I want 1/4 turns or more.
