Piston damage
I’ve got a 92 sn with a 701, 61x cylinder and 62t bottom. Factory pipe, msd ignition and a ada head. I don’t yet know the dome size but the po always ran it on pump gas. It was having starting problems ( in the water) but ran great on the trailer. I decided to start digging and immediately found damage. It’s amazing it ran at all. I was hoping to get some insight on what would cause piston damage exactly the same on both pistons. Appreciate the help.
what dome size ? what was target compression ?
I would assume raised compression, due to additional components and ADA head ?
from what i can see both pistons burnt on exhaust port .....too hot .....and looks like piston wash indicates >>
jetting to lean ? or too low octane gas for the compression ? or both .....
Jcary85
Glenmoore pa
Can’t really tell in the pics but is there any chamfer on your exhaust ports? Maybe it was poorly ported and someone didn’t add back the chamfer.
