piston size?
SUPERTUNE
Race Gas Rules
Clearwater Fl.
81mm is std bore in a 701 engine of any style.
Oversize Pro-X or Wiseco pistons come in .5mm increments up to 83mm.
The 760 engine uses 84mm bore as standard and pistons also come in .5mm increments up to 86mm.
SUPERTUNE
Race Gas Rules
Clearwater Fl.
so would it be a good idea to get the 83mm pistons and rings, cyl are in good shape just rebuilding b/c compression was a little low and im redoing the whole ski, ive refoamed returfed and etc and going all out thats the reason for rebuilding so the rings should seat the difference of the .3 right? thanks so much for the info
