My understanding is that everything should fit together. I did get a set this spring that the pin supplied with the piston was not the correct size. Just do a test fit to make sure the pin slides through the needle bearing and piston.Blue...here is a pic of the domes
The piston skirt length is super critical. Or else the pistons will bind up. You might have to grind it down. When I installed the pistons in a 1021 the skirts had to be machined back more because they did not allow the crank to complete a full rotation. I might have had this issue because the pistons we received were for a 964 and the longer stroke may have caused this issue. But I would make sure they match your old pistons in total length and in the tapers/shape of the skirts.Hello Blue....I have hit both Kyle and JM up already thank you....JM promised to clarify no word from Kyle yet....meanwhile I cleared up the caged bearing issue by doing a match up with the con rod small end and the caged bearing plus new piston pin inside .........that works 100% ....only issue now is the piston skirt is a bit longer than my old piston, but it may still clear the crank web without having to be cut down about 1,5 mm to match the old piston in total height....dont really want to hack it, if I don't need to....will try to mock install and see what clearance is as I rotate crank if I don't get any answer from the builders.
Thats definately an issue on strokers, not so much on the 964 as its a SS. I have had to cut pistons many times to make them fit with the longer stroke. Mocking it up will tell you for sure.Hello Blue....I have hit both Kyle and JM up already thank you....JM promised to clarify no word from Kyle yet....meanwhile I cleared up the caged bearing issue by doing a match up with the con rod small end and the caged bearing plus new piston pin inside .........that works 100% ....only issue now is the piston skirt is a bit longer than my old piston, but it may still clear the crank web without having to be cut down about 1,5 mm to match the old piston in total height....dont really want to hack it, if I don't need to....will try to mock install and see what clearance is as I rotate crank if I don't get any answer from the builders.
If the pistons are black from carbon it would tell you its lean but with black piston domes its difficult to tell especially in a picture. In this case i like to see the domes to make sure they are not black which too indicates a lean condition. If the motor is really lean it will be black on the squish area as well. This area should be silver as the fuel trapped in the squish area should not ignite. Some times you will see a little color in this area but i dont like to see a black burnt stain. If you look at the dome pics posted above you can see a little sign of the black burnt stain on the rear cylinder squish area.@Blue, when you're looking at the domes what do you look for and what does it tell you?
