piston wash?
simofx-1
freeride
new zealand
i had my 701 rebuilt about 30hrs ago, and was wondering how long it should take to show a good collar on top of the piston? at the moment its not that dark at all
simofx-1
freeride
new zealand
i have no pic, because im looking througth plug holes, the ski runs mint but i was wondering if im running a tad rich? as the piston is light brown .
the pistons ive seen are from 10 plus years use and they are black all over
Stockton
Reading piston wash thru the spark plug hole ?....
I have looked thru the plug hole while my plugs are out, for GP, see different things, sometimes it looks black and oily other times it's more dry and clean. When I remove the head though it can be clearly seen, neither was correct. It was a combination of both spread across the piston a distinctive pattern.
These pics are after 30 to 40 hours, race gas, .018 squish, lots of timing early. It looked real oily thru the spark plug hole, I was suprised when I got the head off, I wiped the loose oil off and this stained remained. Unfortunately I didnt take the pics before hand
