piston wrist pin washers
Just4Fun
First World Problems...
Southern Oregon
Rebuilding a 760 motor on a waverunner for a buddy..
Do I reuse these wristpin washers they dont seem to fit with the new bearings sbt gave me
Thanks heres a pic for reference part # 13 in pics
Just4Fun
Southern Oregon
Factory on left new bearing on right is slightly taller I wish I had a micrometer ...
I prob should ditch the washers and kust run bearings, piston should center itself please comment if you are a experienced engine builder..thanks
IS0LD0UT
I hate winter
MN
There are different types of bearings some use the washers others do not.
I want ti say the older 650 ones did not use washera and were bigger.
usa
early 650 use the wider pin bearing that dont use washers
sbt crank pin bearings do come with the wider bearings
they are kaw 750 bearings
wiseco b1023 is the part # for the wider bearings to use and eliminate the useless washers
