Christian_83
Xscream
- Denmark
hola buenas mis amigos se hacen envios hacia argentina
saludos
Shipping worldwide is no problem
saludos
I love this trim but how in the world did they not make an upswept 5 degree option?? Like literally every nozzle that's used on any scream hull uses that. It was for that reason alone I didn't get one. ...And that the nozzle size starts at 90mm. What does anyone with a sub 900cc engine do? Let's me know their composites knowledge is spot on, but freestyle ski build knowledge needs to hit the books. Otherwise that thing is a picasso.
Y On the other hand, i havent seen that quality in carbon jetski parts before - nor innovation
But stay tuned for the finished product and keep checking in - I know they have more parts on the computer allready
Agreed.
With all these carbon parts are you able to get your ski under 175lbs ready to ride yet?!![]()
I'm over here quietly taking a mental note to use a 5 degree nozzle on the DVX I'm building. Weird how you stumble onto little bits of info.
.I love this trim but how in the world did they not make an upswept 5 degree option?? Like literally every nozzle that's used on any scream hull uses that. It was for that reason alone I didn't get one. ...And that the nozzle size starts at 90mm. What does anyone with a sub 900cc engine do? Let's me know their composites knowledge is spot on, but freestyle ski build knowledge needs to hit the books
Just an fyi all scream billet trims are 5 degree and and all Phil's with the billet nozzles are 5 degree. It depends a lot on your hull. If u run a longer one dvx, helium, x1 they like the upswept, if a circus or Richter style a straight can be better. It also can depend on your weight. If you're over 200 u MIGHT prefer straight. And I say might because a lot of buddies I ride with over 200 still prefer the upswept. I rode a dvx with a straight and let's just say it was quickly apparent why scream made their billet trim and all the old style welded up nozzles 5 degree.I'm over here quietly taking a mental note to use a 5 degree nozzle on the DVX I'm building. Weird how you stumble onto little bits of info.
I'd love to know how that intake grate is laid up and how carbon ride plate can be that cheap. Mostly the intake. Layups like that are something I don't yet understand how to do.
