650/X-2 Pjs 830 big bore
Any one have any input or opinions on this motor heard they are rare. Good power ? Worth it for an x2 build? Is 800 a good price minus pistons carb and pretty much just cran cyl head
Its on ebay i won it. It has everything on 650 cases so i guess im green but the heading said rare pjs 830 big bore. Did i get hosed for 850 bucks? Id really like to k ow what im gettin into i heard the pjs viper 7000 was a screamer so i thought id go bigger... Lol
Sospikey
Trying to get upside down
Sweden
You will probably have to work some to get the parts you need to get it running. Most guys drop a 750 motor in there, or even an 800 from an SX-R. Either way, cool project you got there.
Does it look like this? if so you'll need blockoffs for the old intake manifold and from what I can guess very specific pistons to fit the 650 connecting rod. I bought a project ski and this came in one of the bins. Whole kit(head/gasket/jugs/pistons/carbs) just need a decent 650 bottom end to bolt it to. The previous owner was in love with this thing and swore it would be a sweet motor. It does have huge water jackets through the jugs and head for good cooling and I'm assuming it runs some high compression ratios. He also claims its worth $1600 as a full kit.
caseville9036
BLRider
SE MI
View attachment 183040View attachment 183042View attachment 183043
Nice setup, is it an 800 or 700? I like the one that I have. The motor produces a great power all through the throttle range.
Wiseco used to make pistons that fit a 650 rod but were sized to a 750 jug but I've never heard of ones for 800. Probably gonns be a bit of a chore to find those.
CA
Have one
I have a PJS 800 that is suppose to work with my 650 bottom end. Problem is 85mm pistons dont fit into the bottom crank case. 2 big!!! My son is a machinist he is taking the case 2 work to machine it out. Everything else fits.
Have a great day!!!!
caseville9036
BLRider
SE MI
Yes, you have to clearance the cases for the 85mm pistons. You'll love the power you'll have.
I have the PJS Viper 9000 800cc motor which is the same as yours but it's the complete setup mated to a case made specific for that cylinder.
Im actually thinking of selling it complete with electronics carbs everything ready to plug in for $1000 shipped.
It has about 10hrs from new, all hours put on by me.
Very powerful motor..90-100hp
You can still get pistons from John at jetski Haven
I'm considering selling it. I'm thinking of doing a group k 850 big bore and if I get an offer for my 800 I'd consider letting it go
I haven't ridden a SXR but the PJS Viper 9000 is rated between 90-100HP and beleive the 800sxr is 80hp. The PJS motor has great bottom end power and is known as the "HT" High Torque. I had it in a Kawaskai Sport Cruiser and it was running 50mph.
If fastcat777's motor has 85.00mm pistons and is on a 650 caae, it's a 800cc. If on a 750 case, it close to 850cc.
The blockoffs for the 650 location. Can those be plates? or does the blockoff have to have the protrusion for volume purposes?
