I have 2 Snap-On kits just like on the link posted, 0-300 PSI.
If you really get serious YOU SHOULD start with one of these 125 cc kits...
http://www.precisionmeasure.com/block15.htm
When I was in college and couldn't afford that buret package, but was playing with SB Chevys I made my own. Took a rigid piece of plexiglas (big enough to cover the chamber) and drilled a 1/4" hole in it, sealed it to the flat surface of the head with grease and used a syringe to measure the CCs that I added until it filled. Use water mixed with a little alcohol to make if "thinner." I've pulled that setup out and used it in the past few years to identify the dome displacement on ski domes too.
