Polaris Octane Stators
OCD Solutions
Rentz, GA
http://www.jetskiplus.com/polaris-s...ctane-slh-virage-off-running-ski-4010172.html
The above listing has the following compatibility list. I can't vouch for it's accuracy but it's a start.
Used stator off of a running Polaris fresh water ski, it's in good used condition.
Please ensure your model and year PWC is listed below for proper fitment.
This part will ONLY work on models and years listed below:
2002 FREEDOM
2003 FREEDOM
2004 FREEDOM
2003 OCTANE
2002 OCTANE
2004 OCTANE
2000 SLH
2001 SLH
2004 VIRAGE
2003 VIRAGE
2000 VIRAGE
2001 VIRAGE
2002 VIRAGE
Apparently there were two different stators with matching flywheels. You need to use a matching pair otherwise your timing could be advanced really far or retarded. So if you buy a matching set from a running ski, you'd be good. Otherwise, just scour the microfiches looking for the same part number stator.
VXSXH20
Sionis Industries
Mid-Atlantic
some of the flywheel and stators pre 2002 were " high start " which had about a 10 degree advance on them. most Elecs after 2003 were standard. The subsequent model year stators tend to last longer than the pre 2002.
mine is an 03 which gets about 5 min of ride time every year lol. but its also running 230 compression, 110 octane, lightweight flywheel, and a few other goodies. so if it did advance it 10 degrees it should handle it. Thanks so much for the help gents
Ducky
Back in the game!
Charlotte, NC
@truerider411 ....here are the cross references I could find.
