Would you have any link for this type of bracket? My research only shows the the Blowsion standard 2 holes bracketThat is a UMI. Its a 1 piece design. Blowsion has bracket. My favorite is an R&D. But you have to find one with a hood mount or fab up a custom hood mount since your FX1 has the mount on the bracket.
Thanks.https://www.blowsion.com/fx1-billet-bracket-clip
You can link to the adapter and also the bracket.
No the aluminum plate/shape you can see on the picture that is under the UMI backet. This plate is filling up the open space left by the FX1 iconic backet/pole cover.Talking about a plate that goes inside the hull where you bolt tue bracket down?
Sent from my SAMSUNG-SM-G930A using Tapatalk
If you're a little crafty, you could make it out of fiberglass. Would be easier and cheaper than having it fabbed up unless you've got some hookups!Ok
Thanks for the replies.
I like it, so I'll have to figure out something for it or similar
Fill it in with Hydroturf.Ok
Woooow I like that . Different, yet simple to make. Thanks for the idea .I made this aluminum checkerplareView attachment 317024 one years ago, then blasted it and painted black.
I like "waaay cooler" and " unbreakable"It was unbreakable, easier to get weight forward, and waaay cooler!
