- Milton, Florida
Generally speaking, if you are a tall guy, would you want a shorter or longer handle pole compared to a short guy? For freestyle backflip riding
tall guy and or long arms is needing a shorter pole. rider weight distribution needs to be centered on the ski for best ski handling performance. long pole and hanging off the back is not the proper body position. footholds farther forward and hella short poles make for a better center of gravity on the ski. flatwater freestyle. boat wake flips and rolls isn't as critical
My understanding was that taller guys go shorter poles, in generalIt's like a golf club ,shorter the guy ,shorter the club ,but it really comes down to rider preference,I'm short as ,163cm and there're guys taller than me I ride with that run shorter poles ,it really comes down in the end to how you like to set up your ski and feel comfortable![]()
I have the same hull as you, and am 5 10. My rrp pole has about 2 inches of tube showing and its been great for me. I could probably go shorter and still be fine. I'm not real tall but I have always preferred a shorter pole. Even on my full length squarenose I had over a -8 inch pole setup.My understanding was that taller guys go shorter poles, in general
Do you have a pivot to pivot measurement? I have a different poleI have the same hull as you, and am 5 10. My rrp pole has about 2 inches of tube showing and its been great for me. I could probably go shorter and still be fine. I'm not real tall but I have always preferred a shorter pole. Even on my full length squarenose I had over a -8 inch pole setup.
One thing I noticed for me was when I went to a shorter ride plate the nose pops up more which made me want to shorten the pole length. That may be a variable to think about too.
I am going to try a shorter pole length next year, per Mike B.
I am quite short, so it makes hitting the chop harder to ride ( nose into waves). I suppose at some point a guy had to pick his poison and use that hull for what it's specified for.
Overall, from what I have heard is the shorter the better for flat water.
