Pole pad to painted hood adhesive?
title says it all. What adhesive to use for installing a pole pad on a painted hood? EME aerial 8 if that matters. I know for “normal“ turf install weld wood is the go to just wasn’t sure how it would adhere to paint or if it’s overkill in this application. Thanks in advance.
+1 on weldwood. If you sand the paint where you plan to mount the pad, and apply 3 coats to both the padding and the hood, then let It air dry thoroughly, it will hold up strong enough that the padding will tear before the glue fails. Had my pole pad blow off yesterday when landing inverted from a under rotated barrel roll. The padding ripped, leaving a patch on the hood.
