Vumad
Super Hero, with a cape!
- St. Pete, FL
A Superjet is OK with its stock 8mm cooling line. Old Kawasakis with 7mm lines and fittings will get hot enough to scald. Most electric bilge pump failures come from debris (zip-tie tail) stopping the pump. Siphons are good to keep if possible.
Good info. That's a significant difference. My sxr was set up parallel cooling for racing and I was wondering why. My 750 x2 was running very hot on the pipe side so I switched it to parallel cooling and am getting better temps now. My Superjet almost runs cold with dual cooling.
Yours is a good explanation for why.
