I really don't like making absolute statements. it is entirely possible that 2 mechanics
can have different skill sets and work experience that apply to the same subject. But this
nonsense about pop-off has been going on for more than 30 years.
First: Pop-off is a better tool for rebuilding carbs, than an individual circuit to be
modified.
A (lower) pop-off for his situation is needed because he has aftermarket flame arrestors reducing the intake tract pressure
from what the stock f/a produces.
This is incorrect for many reasons.
1). Why, why do you think you need to reduce pop-off pressure more than once?
You lowered the pop-off pressure with the FPP pipe jetting(115gr to 95gr), and
then you want to reduce it again because it has aftermarket flame arrestors (FA)?
2). You are assuming that the flame arrestor is restrictive. But most Kawasaki,
SeaDoo, and Yamaha flame arrestors are not restrictive, and there is little too
no performance increase when you install an aftermarket FA.
3). The Mikuni Manual was written before the SBN was sold, and during the
70's, 80's, and very early 90's there were some restrictive oem FA's.
The graph in post #18 is another example of inaccurate documentation in
the Mikuni Manual. So is the idea that carbs dribble because the main jet
check valve is too thin.
4). Air is not sucked into the venturi, it is pushed in by atmospheric pressure.
5). I know what you meant to say, but:
"because he has aftermarket flame
arrestors reducing the intake tract pressure" Reducing pressure implies
increasing negative pressure, hence increase ported vacuum (or air speed).
Both help the carb to increase the fuel to the venturi.
Another fun fact, fuel is pushed into the venturi.
I'm not saying that 40+ pop-off is wrong for some applications as each engine is different, but the most common effective
numbers are what have been recommended here.
Yamaha carbs were designed to run Hi pop-off pressures and lean low jets,
and they were equipped with a free flowing FA.
Yamaha carbs (compared to aftermarket sbn's) have a different throttle
butterfly and low speed by-pass configuration. They are not the same.
Factory does also state in their manual that their specs are only for a fully stock boat that has nothing else aside from the pipe.
Stock FA are free flowing, it's loony tunes to change pop-off twice.
Just wanted to point that out not as a contradiction to what you are saying but just for clarity to others following along
, pop-off
is just another component of tuning mainly to get your fuel delivery timing back on spec
Which spec is that?
If I rejetted a super jet for a pipe, FA, head, porting and I kept the stock 115gr spring,
and the power delivery was "as expected," and you could hold the throttle wfo until
you were tired. Isn't that the goal??
It is possible because I treat the seat diameter and spring rate as team players, along
with the low speed jet and pilot screw.
Bill M.
Anyone can learn how to set-up their pop-off, low speed circuit, and pilot screw by
learning the Idle Drop Test. In addition the idle drop test will prevent the low speed
circuit from killing peak rpm, and make it easy to recognize when pop-off (and the low
speed circuit) is too rich.
