Port Timing & Duration Specifications
Nobody has an anwer because they don't really have / use bottom end power.. I think people confuse "mid-range" power and accelleration with bottom end.. Maybe Wax, Chuck and Zero can post a few torque curves for review since nobody is answering your question.
Bottom end = The power you need to tow your buddy's ski back.
Mid range = The accelleration and torque necessary to perform a backflip
Top-end = The peak rpm and speed necessary to outrun the river patrol when riding in the 5mph zone.
Best regards,
Randy
Most people think of bottom end as probably 250-1500 rpm.
Truth is, you hardly ever spend any time at that rpm.
When I hit the throttle, the motor goes past 3000 rpm within the first half second, before the ski even hardly moves.
Wow #ZERO ! this is awesome info to read ! good reason to have a builder cut custom domes for MSV / max safe compression...
The tapered angle on the squish band is there to help the squish action; it forces the charge to where the spark plug is located and is generally one or two degrees more than the angle of the piston. A narrow squish band ratio allows for more of the total intake charge to be located in the combustion dome resulting in more power potential during spark ignition near TDC. The down side is that there is more piston/dome area that is exposed to combustion on a highly loaded engine and heat build-up can become an issue that could eventually lead to detonation. As RPM increases, there is less time for combustion and a shallow dome designs will take less time to scavenge and refill vs. a head with a deep dome. Most pump gas engines tend to like a wide squish band width and smaller diameter domes with more volume. Race gas engines like narrow squish band widths and larger diameter domes with less volume. The squish band area or ratio can vary with each engine and usually is between 30 - 60 percent of the bore size and the larger squish ratios require greater squish clearances to get equal velocities. There are many factors that come into play to get the correct maximum squish velocity or (MSV), such as; RPM, squish clearance, squish ratio, rod ratio, compression ratio, port timing, blending radius, diverging squish angles, fuel type, etc. and it can get quite complicated. You'll need a computer program such as the Bimotion advance head design software to calculate all the factors. This squish program enables you to calculate the MSV of turbulence in the combustion chamber. This is an important design tool for finely targeting the hit in the power band and to determine a link between power band and fuel. The squish ratio, dome shape, compression, MSV, etc., all work synergistically while at the same time are all a compromise. There's a fairly delicate balance that needs to be maintained and small changes are better than larger ones. Increased MSV will help speed along the flame front and complete the combustion process more efficiently, but fuel choice will limit MSV. There is a point where the friction from the squish action can be so great and happen so fast that it generates enough force/heat to ignite the charge. Some basic MSV numbers that have been around for some time range from 15 - 30 meters per second. This is divided into two groups, high MSV and low MSV. Lower MSV numbers, around 15 - 19 m/s, generally make power from peak torque to max RPM or mid-top power. Higher MSV numbers from 20 - 30 m/s generally make power up to peak torque and then start to go flat. Also MSV numbers that are too high will kill off over-rev and lead to detonation.
Here are a few things that can either raise or lower the MSV.
Factors that raise the MSV:
Lower Compression Ratio
Less Squish Clearance
Larger Squish Area Ratio
Higher RPM
Smaller Bore
Longer Stroke
Shorter Rod
Factors that lower the MSV:
Higher Compression Ratio
Greater Squish Clearance
Smaller Squish Area Ratio
Lower RPM
Larger Bore
Shorter Stroke
Longer Rod
Here's the Bimotion head software: http://www.bimotion.se/
Free squish velocity program: http://www.torqsoft.net/squish-velocity.html
dfw
I see that most here always talk about bottom end, mid to top, and top end power rpm ranges. I'm currious as to what rpm everyone here equates these ranges to and if the ranges are tach derived or just feel. I'm just curious. WAX, ZERO this isn't for you to answer just yet.
Its all from a riders perspective as to how the engine responds to throttle input. Our skis are not connected to anything solid like a car. Thrust occurs only when the engine is at high power/rpm. ANY power that the engine makes below stall rpm is felt as response more so than thrust. Low port engines make more power below the pipe so they are more responsive. High port engines suffer until the pipe starts working. Matching the pump load is very important especially with high ports.
Thats funny Randy, my tach doesn't have numbers on it, instead its divided into three sections of: Pull faster I'm sinking /// This is strange, where's the water? /// Oh crap, how well jetted is this thing?
dfw
Depends on your fuel budget. Cheap gas = lower ports. Expensive gas = higher ports. Then impellers need to bent to perfection.
WFO Speedracer
Alabama
I guy named Walter Rainwater used to port my Aluminum 440 cylinders for me back in the day, he removed the cylinder liners , he had a cylinder that the ports were already cut on but the cylinder was bored out so the liners were a slip fit into them, he would then Dykem the liners , mark them with a scribe and cut the ports .
He had another set of liners he had already cut the ports on but the sleeves had been turned down on the lathe so that they slip fit into the cylinder , he would drop those liners into the cylinders , mark the cylinders and cut them , then reassemble everything and finish up the port blending , that was one of the smartest ways I ever heard of doing cylinder porting. Walters work was immaculate and those old 440's ran really well for what they were . Walter is in the post below.
WFO Speedracer
Alabama
Walter Rainwater South & Central Regional service coordinator ;
I have enjoyed more than 24 years at Kawasaki as a service instructor. My first year with Kawasaki was in Avenel, N.J. After the first year I moved to Atlanta. I have always been a service instructor. My other responsibilities through the years were warranty coordinator, customer service, and the Hot Line. Of course, the warranty and customer service were done in Atlanta, long before these services were consolidated to California. I have seen the company grow and have seen the introduction of many new exciting models. When I joined Kawasaki in 1972, the latest and hottest model was the H2-750 triple. It was the fastest of a long line of two-stroke motorcycles that gave Kawasaki its image as “King of performance.” I remember hearing rumors about T103—that was the project name for the legendary Kawasaki Z-l. The Z-l elevated Kawasaki to a level all its own in the industry with speed, beauty, power, and unmatched reliability. Kawasaki was known only as a motorcycle company. In 1972, people were surprised when we started selling a “boat” known as the Jet Ski. It started slowly, but over a period of about 10 years Kawasaki created the personal watercraft industry. In 1974, Kawasaki opened a manufacturing plant in Lincoln, Neb. It was the first of several manufacturing plants in the states. Kawasaki continues to explore areas of new product designs such as the MULE. The basic MULE design evolved from changes to an ATV, and its project name was Pony. As I look back over the years, I have seen Kawasaki grow and prosper. I am proud to be a part of it. I am anxious to see what the next 30 years will bring.
Walter Rainwater 6110 Boat Rock Blvd. S.W. Atlanta, GA 3037
Walter died back in 2013 , he is the mentor that taught me most of what I know about two stroke high performance , I attended the Kawasaki High performance watercraft school in Atlanta Ga. back in the late 80's , early 90's , the Chart that is floating around telling you what all the numbers on the Kawasaki cylinders and heads mean is some of Walters handiwork and is straight out of a Kawasaki K tech news bulletin which Walter was a contributing author of , he was a wealth of knowledge on anything Kawasaki related, he is sorely missed RIP Walter.
