- Tuscaloosa, AL
I'll say it's ported alright.
5mm cut from the top of the exhaust. :shocked:
Sounds like a Mission Yamaha port job, they had some really wild port specs.
im just trying to see if i can use this other ported cylinder for a freestyle boat cause it was in a race boat
any more advice?
You are pretty much out of options. You've got a couple choices:
1. use either of these wildly ported cylinders and then add every other low end band aid you can think of (higher compression, total loss with lots of timing, small impeller, etc) to try and get some bottom end out of it and see if that is good enough for you...oh yeah and be permanently haunted by the fact you are running a sub-optimal setup, and know deep inside that you should have done it right the first time.
or
2. buy a different cylinder, preferably one already freestyle ported.
or
3. Give up on patching your old motor back together and buy my old Team Scream 828cc stroker and KNOW that you can't get more braap for the $$$ anywhere else in the world.
I'd say sell both on ebay and advertise as "ported for racing"... Then buy a used 61x off here.
yup that's what im gonna do sell them both and maybe have enough for a freestyle one.. this was a super stock race ski and i just blew it up for the second time so im starting off all over
