I'm curious what you used to determine the shape, profile, and cross-sectional area of the ports and how you came up with the amount you trimmed off the lip on the sleeve for the boost port? I am by no means saying its wrong, just curious on how you came up with it because I'm a little skeptical using a template for a porting job no one has verified. Either way I'm happy someone is getting into this since Race Logic got out of the game; if these work out well you'll make a lot of people happy
The shape is based on different porting jobs I have looked at, and or ridden, it is actually pretty similar in shape to the stock port. The roof and floor of the port have not been modified, the port at it's widest point is 68% of the width of the bore in which it was designed for. The intake side/boost port area is also based on cylinders I have had in my hands (some where longer, some shorter). I understand your skepticism and I am more than willing to refund your entire payment if you receive the templates and are unhappy with them. I am not a pro engine builder and am not a two stroke guru, just a guy who has ridden a lot of motors, looked at a LOT of pictures, read a lot of threads and a handful of two stroke tuning/theory documents, and done a little bit of CAD work and math.
These were created to provide an ample power increase across the RPM range, be relatively simple to perform at home and be on the safer side of the modified area to allow a bit of wiggle room if somebody gets out of hand with their grinder. They will not get you the maximum performance possible out of your cylinder, you WILL need to pay a professional for that. I am not trying to push these as the best porting option available and I would honestly love some feedback from an actual engine builder (although I can already guess what their thoughts are on this type of product).
I am not sure if the Sport Port template I have here has been modified at all but it is their "yamaha freestyle template" and it measures out to 73% of an 81mm bore and 71.4% of an 84mm bore, at its widest point.
