Decided to buy a set,cause l was in need and also going by your recommendation.Waht l read has been positiveThe gear wrench tap and die set is spendy. But the quality of the taps and dies is better than any other set I've come across. Along with the ratcheting tap handles, I just dunno if there is a better kit out there.
Sent from my SM-G970U using Tapatalk
Does it damage the studs when you pull them? Some of them have teeth that can eat the threads.This stud puller set has been worth it's weight in gold for Kawasaki motor rebuilds and anything that uses studs:
Amazon.com: Assenmacher Specialty Tools 201 Metric Stud Remover/Installer Set - 4 Piece: Automotive
Buy Assenmacher Specialty Tools 201 Metric Stud Remover/Installer Set - 4 Piece: Tool Sets - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
They have 3 rollers that grip the stud. If they are on a threaded spot on the stud it will flatten them if a whole lot of torque is required.Does it damage the studs when you pull them? Some of them have teeth that can eat the threads.
Sean
Hi sir,This is a handy tool if you have a fleet, or alot of toys. Its really easy to load. And will push through almost any plugged up zerk
If you don't have a tight area check out the Lock LocknLube ends. They are expensive, but usually come with one rebuild kit. If you use it occasionally it should last you a lifetime... I also recommend any Lincoln ends if you need weird grease adapters.In that line of thinking, do y'all have a recommendation for a decent grease zerk fitting? Not the one that goes on the part, but the one that goes on the gun? I have one that refuses to connect properly and it drives me insane.
Sean
Sean
