Possible ptoblem with Raider trim on B-1
With a stage name of Radical Riche, you should remove that 5mm steering cable before you bend it.
I have the bracket, heavy duty 6mm cable, and cable ends in stock here.
http://www.x-h2o.com/index.php?threads/blaster-1-steering-system-parts.188715/
Rod is not the problem, the sleeve needs to be reinforce to stop the cable rope inner flexing too much and kinking the sleeve
I thought that it was a solid inner rod that ran from the steering nozzle to the steering column.
Mines 2” rearward. B2 cable with 2” stainless extension. I know it’s different but principle is similar.
