227
Its all about the surf!
- Oceanside, CA
On my last ride I landed a little inverted on a Backy and clearly did some damage. Not a pancake (I've done plenty of those) but just came in hot. When I came up my ski was grinding and making all sorts of noise. Gave it a blip of throttle and I was clearly in neutral, so I thought I'd broken my coupler. I had to get towed in. When I got to shore a quick inspection told me my coupler was OK, but that I had broken some motor mounts. When tearing it all apart I discovered that I had actually broken 2 motor mounts, and the remaining 2 broke when I removed the motor (Not when I was riding). My coupler is OK, so I'm thinking striped dive shaft splines, however when I pulled the pump my drive shaft splines also appear to be OK. When it happened my ski was running and wasn't going anywhere, even after giving it throttle. So I guess my question is; Do the interior splines on the midshaft strip out without really damaging the drive shaft splines? Unfortunately you can't really see the interior splines on the mid shaft in this picture but to me my Drive shaft looks OK or am I reading it wrong?
Does this look striped?
Here's the Mid Shaft, I know you can't really see anything
