Possible trick for all you ski capable freestylers.
SW UT
What if you had a compressed air tank you could switch on and seal off the engine compartment intakes? So say you had continuous air and didn't suck in any water when you went under, think it could happen then?
Just thinking out loud, but if you somehow did have an air tank under the hood, that you could activate, why would you need to close the intakes? Just have the tank release enough air to feed the engine, and excess to leave the compartment via the vents....
Just my thoughts, I could be overlooking something exceedingly simple.
SW UT
Then you would need a bigger tank, so more volume and weight.
Just think guys that are doing more than one flips and not completing there rotation going underwater and with enough momentum there getting that second flip. Anything is possible
emachines
SCUBA STEVE
binghamton, ny
I had a go pro video of this on my stock SXI but I lost it lol ... .....IMO it'll be done some day........If you were to tell me 15 years ago people could front flip a dirt bike, I wouldn't have believed it for a second.
I'm with you on getting them to sub....but I say if you can stab a straight suicide sub maybe 1000cc+ and sick pump would propel you up and out...if it didn't run out of air trying. It would have to rev hard and perfectly under the water for a couple of seconds. Mine accelerates bad under water because it seems to run out of air instantly.
Get a Few of these and mount them inside the hull. Might and thats a BIG might do the trick with running out of air.
http://www.google.com/products/cata...=X&ei=gnNsT_KFFeWC2wWRxJ2EBg&ved=0CKIBEPICMAo
PWCSAR
River Rat
Wa
That's kind of what I was thinking reading this whole thread "add an 02 tank" on a switch.. Might as well stick in nitrous while your at it. You'll fly out of the hole!!!!
