Post pics of your ski......
wi
family skis
I know these are not even close to the caliber of skis on here but here they are.
-94 fx1 all the way on the right (mine): Fully ported 735cc, b-pipe w/ fx1 chamber, black ada girdled head with 35cc domes, boyesen power reeds, lightened flywheel by php, flow control valve, dual cooled, rev limiter mod, Tornado flame arrestor, tdr waterbox, 144mm pump w/ superjet intake tunnel, pro tec nozzle, jet dynamics reduction, solas concord, reinforced, r&d sj scoop grate, d cut ride plate, blowsion quick steer and bars, odi grips, umi throttle, pole spring, dual 500gph bilges, hot feet, footholds.
-94 fx1 in the middle(older brothers): 701, b pipe w/ fx1 chamber, girdled head 35cc domes, lightened flywheel, dual cooled, flame arrestor, reinforced, msd enhancer, 144mm pump, pro tec nozzle, scoop grate, quadrafin rideplate, hoooker, blowsion bars, odi grips, umi finger throttle, pole spring, bilge, footholds.
-91 Superjet (ours): stock 650, boyesen reeds, straight bars, pjs finger throttle, r&d scoop and rideplate, ss impeller, pole spring. plan on getting a 701.
CIMG0378.jpg ^^^ not all of us can afford 8K machines... just work at it little by little. this is my 92 SJ and my brother inlaws 91 SJ is the tray in the bottom of the pic... this is a pic right as i started the tear down... will have to post updated pic when it is painted.
Reinforced hull
pulled stock 650, dropped in stock 701 with 35CC domers on an ADA girdled head
Solas mag pump with 9/15 hooker
TOBY footholds
Dual Bilge
Aluminium pole w/ 0 degree bars
scoop intake
"custom" D-cut ride plate
Cant wait till she's done... come on spring!!!
chadman154
#Itsonlymoney !!!!!
Dirty south
View attachment 206011 ^^^ not all of us can afford 8K machines... just work at it little by little. this is my 92 SJ and my brother inlaws 91 SJ is the tray in the bottom of the pic... this is a pic right as i started the tear down... will have to post updated pic when it is painted.
Reinforced hull
TOBY footholds
Dual Bilge
scoop intake
Some pay more than 8k for the hull alone..... You gotta start somewhere
