- East coast
First season running a powerfactor. Ran rrp in the past and worked great. Switched to pfp. I’m having issues with waterbox loading with water very easy and doesn’t seem where it should be on low end. If I am anything other then pinned the box fills very quick and takes 2-3 wot to clear it out. I have tried turning fcv all the way both ways and doesn’t seem to make a difference. I am now running it basically all the way closed. I went from the stock jet (130 or 140 I think) down to a 110. Seems like it helped a tad. Should I go down in jet more? I just worry about small jets clogging in surf. Should I get a different fcv? Chamber is cold, waterbox is pretty warm but not melting couplers. Any info appreciated don’t know too much about these pipes
Hull glass Tigercraft V2x
Motor 61x/61x 781 bb single 48 novi
Pipe new style pfp
Pump 148 mag
Prop skat swirl 6/14 5mm cutback
Light flywheel with charging system
Water temp in nj right now prob high 60’s
Pipe new style pfp
Pump 148 mag
