Power Valves - Care and Feeding?
Aquaholic
World's Oldest Teenager
San Diego, CA.
What's the care and feeding like? I've never had a motor setup with these things before. What's involved,maintenance wise, with these contraptions?
Anything special to keep an eye out for?
SUPERTUNE
Race Gas Rules
Clearwater Fl.
The XS 1000's do get just a little bit of oil build up in the bellows, so just a simple cleaning every 3 months and replace the bellows once a year to keep them from getting stiff from the race fuel.
When you run a heavy mix of oil... the power valves don't get caked with carbon like you would if you ran oil injection or like 50:1 premix.
Aquaholic
San Diego, CA.
Interesting. How does that work? I would think that by running a heavier oil mix... that the Valves would be more prone to gunk build up.
Pablo
sqeez bth levrs & lean bk
georgia
anyone know which orientation (#1 or #2) is correct for the guillotine slider on a power valve? I pulled mine to inspect and didn't pay attention to how the slider was positioned. Each slider has a tapered tip as shown in pic.
canada
all the PV i have seen the beveled edge went flush with the cylinder like #2 if it was put in like in #1 the piston would hit it because i stuck in further cuz of the angle the PV is on. this is just what i have seen.
