Freestyle Poweractor dimensions
norcal ex
X-H2
San Jose, CA
I need some dimensions for a powerfactor pipe to see if I can fit one in my ski with the current setup.
1. What is the forward most point of the chamber measured from the front exhaust bolt? (How far does the chamber go forward)
2. At the very forward point of the chamber what is the diameter of the chamber. This is the largest part of the chamber I think.
temecula
23 1/2" from center of front bolt hole and 8" diameter at the largest section which is almost straight out from the manifold. It just slightly reduces around the bend to about 7". Hope that helps.
