"PowerFactor" Dry Pipe
IKSTEJ
BOGIE
Region 7
We've been running "Powerfactor" pipes since April, and all I can say is it is
( By far ) the greatest Bolt On performance gain we've ever made.
There is absolutely no comparison in Bottom to top power/torque to the
B pipe. Not even close.
Its a real cheap way to make a whole lot of power.
heres a nice pic of the pipe on the bench.
http://www.xmetalworks.com/prod.html
demolition_x
Not After Fame & Fortune
why can't they make the pipe expand more in the nose of the ski where the waterbox would be and even into the nose foam so you can keep the stock tank?
it looks pretty just wondering why both this design and the eme design makes you get ride of the stock tank.
SuperJETT
none
News Flash: 'EME pipe' = Powerfactor pipe, Powerfactor is the new company Mark Baxter (formerly of Factory Pipe) has/is forming to do engines/pipes, he is who built the EME pipes.
Tuscaloosa, AL
bore, stock bore. geek has one, Pat ran one when he won the amateur national title so he was 100% legal.
Still not making any since. You have a stock stroke, 5mm, 6mm and 8mm. Plus some oddball sized. But I do not see how you could have a 8mm stock stroke.
So what would be different from a stock stroke and an 8mm stroked crank.
