Freestyle PowerFactor gas tank and battery setup?
Watty
Random Performance
Australia
That's a customers Dasa 950 we just freshened up ad tuned. It runs 48mm Powerbombs and prob gets around 15 minutes of solid stunting on one tank.
IS0LD0UT
I hate winter
MN
Any new developments on this? I know thrust has a new tank, however with my setback motor I cannot fit a battery behind the mounts.
I have my jazz tank strapped down and to the front cover of my motor, but it shakes quite a bit as the motor is running. I am worried the tank will get a hole rubbed in it or rub the hull. Does anyone make a tray/mount for the 3 gallon jazz?
This is what I came up with for my 3 gallon tank.
This is what I came up with...
I wanted to mount the battery in the rear of my ski to open up my options for a gas tank. Purchased a riser from Blowsion which allows water flow under the battery tray (probably not needed but I didn't want to block the scupper). Because of the XFS-R tray I couldn't mount the battery upright so, I designed a battery tray which allowed the battery to be mounted on its side and had it CNC'd at a local shop. I ordered stainless steel inserts and RRP strap hooks from Thrust and had the inserts powder-coated to match the inside of my hull. I epoxied the inserts in place with black Plexus MA 320 (stuff is amazing). I didn't mount my tank straps to the flywheel cover like some suggest. I used 4 inserts to hold the gas tank, 2 to hold the power box and 2 to hold the chamber (I used a couple of stock mounting locations for the chamber.
Christian_83
Xscream
Denmark
I rotated my cart tank by 90 degrees and made a small carbon battery tray to fit between tank an PFP pipe. Im running a normal 9ah battery and MSD TL
389445_10151496138259992_1807409629_n.jpg375812_10151495794034992_1817797978_n.jpgIMG_2859.jpg
IS0LD0UT
I hate winter
MN
I don't know how you guys do it with the small 2 gallon tanks. Certainly my issues would probably go away if I switched to a different tank.
It is really hard to resist going back to a b-pipe and a CF tank.
Christian_83
Xscream
Denmark
Thanks Jay :) poor pictures, but thats what i could dig up and im at work for the next 10 days.
Yeah 2 gallons of workout, then i need a break to :)
mxwilbs
A-ron
Rochester, NY
I had this one built by a family friend, holds the battery and 5.1 gallons. I have about and inch clearance all the way around, so i can work on things easily! My brother Erok had one built very similar which was sold in his superfreak(picture already posted). I think its money well spent, and it works amazing. IMG_2317.jpg
IS0LD0UT
I hate winter
MN
I had this one built by a family friend, holds the battery and 5.1 gallons. I have about and inch clearance all the way around, so i can work on things easily! My brother Erok had one built very similar which was sold in his superfreak(picture already posted). I think its money well spent, and it works amazing. View attachment 224389
SOB! I want one of those!!!!! How much was it? Did you have to drop your ski off for them to fab it up?
