kind of new to jetskis and just wondering what oil i should run in my gas...i have a 650sx
tech 2000 $5 for a gallon at walmart.
any tcw3 oil will work just fine.
you can pay more for better oil, and get slightly better oil ( sometimes)
but its false economy, the oil cost over hundreds of hours of use is more than the cost of a top end.
I use to think like you :banghead: Not after tearing down my motor this last time.
Now Id have to say your crazy :biggrin:
can i use the same stuff i run in my dirtbike?
most likely you could... 40:1 is the general mixing ratio of a PWC oil.
If you want it to smell good there are additives you can get from a speed shop or in my case local stock car shop that makes the exhaust smell like strawberry or cherry.
Mark44
do they make castor 927 flavored?
I love that smell.
I need to try that pennzoil stuff, my only beef with the tech200 oil is the smell, it doesnt smell pleasant at all.
Agreed, I use Pennzoil %100 synthetic from Wal-Mart 20 buck a gallon and my last motor still looks great inside after four years of that oil. Very minimal build up in the chamber so I would say this oil worked out just fine for my application. I now have a ported motor with high compression and still no problems from Pennzoil and that last motor is now a spare sitting on the shelf.
Mark44
Thats a hole different game then the non synthetic crap that Flake is talking about..... Anything 100% synthetic should be good to go.
