SuperJETT said:One thing to think about is, if you're pumping into the pulse fitting, and your reeds actually seal well, you're going to be putting that pressure on them and they could be damaged. I like to leave the reed cages out when I do it just to be safe.
the reeds should seal very well. however, at the rate that youre pumping air in, they wont seal that well. its not like youre suddenly zapping the engine w/ 8 lbs psi. youre gradually pumping it into the engine.:cheer:
