I use the bulb type it is under my hood and has lasted for 3 years now. The one before this lasted 2+ years.
Mark44
I think they dry-rot/break a lot quicker when exposed to sun light all the time.
Well I had bought two new ones already. Went to switch them out last night and both the old ones were working again..?.. I tried the WD last year and couldn't get them to break free. It would be easier to replace them now and not have an issue all season but that would be too easy. I'll keep a spare with me and change it at the lake if I have to.
I would think a bulb under the hood would be a pain in the butt. I have to prime mine every time I start it. Sometimes I have to prime even if I've been riding for a while and just fall off...
Sounds like you need to tune your ski.. I know that can be easier said than done... I dont have primer at all and my ski fires up instantly.
I spent a good bit of time messing with the carb last year. I had issues with it dying at high speed. Got that fixed and it runs great low and top end. I could be a little lean on the low end but I think if I was lean enough to cause starting issues it wouldn't run good at the low end.
Might be a small air leak. I have to prime every time I start if it has set for any amount of time and maybe once or twice all day while riding.
