- new jersey
So I tore down my square for winter build, re-installed everything yesterday, tried starting and only heard buzz/hum and negative terminal started to smoke.
What I did prior to starting : hooked starter plugs (black-black, clear-clear), ground line from ebox to bolt on block I think from starter, new plugs, positive cable from ebox to battery, negative from under engine to battery.
Battery was in garage all winter, so I threw it on the battery tender. After 1 1/2 days the green light appeared. Can these trickle chargers bring back a battery or just maintain them?
****Notes****
93 superjet, 701 stock ignition
This was a good working battery last year, as was the rest of the ski.
Engine and ebox were stored in my basement all winter. When I picked it all up to re-install, the ebox had condensation on outside. Although ,it has been humid lately.
Everything is where it should be. Did I fry anything? Will a new battery help?
****Notes****
