Problem with full speed
Hello, I would like to know, what could be problem on my KAWI SXR 800 /factory wet pipe, flame arrestors/
When I'm run full speed for maybe 15-20 sec, the engine slow down and turn off. After that, I start normally, repeat it and had same issue.
Petrol is 2 weeks old, half of tank.
Today it was the first time, what it happends.
Does anyone have experience with this?
Thanx for answer
SUPERJET-113
GASKETS FOR CHAMP BRAP!
@Matus
Sorry, i meant wet pipe. When you put on a after market pipe you have to re jet the carbs. The pipe make much more power than the stock OEM exhaust pipe, yhus needing more fuel... You are having lean seizures and probably having some scoring now on your cylinder walls. Do not run it any more until re jet.
@Matus
Thanx, maybe it was done, but I'm the second owner and don't know, what have been done.
Ok, how can I check it?
Big Kahuna
Administrator
Tuscaloosa, AL
Did your replace the water fitting on the pump? If you bought the Factory Pipe new it would have come with a new 1/4 x 3/8 fitting. If you did not replace it then the motor can run hot and the over heat sensor would put you in limp mode until it cooled off..
Yes I did. Must try preassure first, but here in Slovakia is 23:00 now, and can't go to try it now ;-)
And thanx
Hello,
Today I measured preasure. Both have 95 PSi, insert new NGK BR8ES spark plugs, check fuel tank if there is no some dirt, or stuff.
Ask the first owner if was rejet carbs - he said yes, they was modified.
Tomorrow wanna try on water with fresh water. Hope everything will be fine, and my problem, was only low fuel in tank.
Is anything what can I do or check?
Thanks friends
Hello,
Tomorrow wanna try on water with fresh water. Hopeeverything will be fine, and my problem, was only low fuel in tank.
Thanks friends
If your compression is really 95 PSI, that is far too low. The consistency between the two cylinders may suggest a faulty gauge. Recheck with another gauge for good measure.
Did you mean one more check with another gauge? Other type or so?
I found some vids and on one have spark in and than meassure, in other both sparks are out. I was measuring With spark plug in...
Thanx for help
Have question, if I want to remove head - to check pistons etc, and after check everything looks fine, it is just to take it together again, or is necesary to change gasket, or and some lubricants or something when it put back? Thank you
