Project "Faster Blaster"
Folks,
This is a build thread for me to post and refer back to in the future. If my frustration, mistakes and finding help others, great! I'll no doubt be asking some questions.
Picked up a low hour, bone stock neglected Blaster in July. I say low hour because the mid shaft rotates smooth and if I had to guess it (along with all other components of the ski) was never serviced. Oiler was intact, pump had compost growing in it etc. Badly weathered/neglected, but didn't look like it had been ridden much. Not a single chip on the impeller, cylinders unscathed with honing marks still present, pump bearing smooth, minimal play in steering bushing... Once I got it running, it ran perfectly smooth even though I sincerely doubt the carb had ever been apart (factory paint still on perfectly un-marred screws).
Glass work:
Fall starts in mid Sept in my part of the world, so that's when the teardown began. It was crashed into a dock by one of the previous owners so that needed to be addressed. I did 3 layers of chop strand fiberglass + resin to build it up then marine tex to rebuild the body line. Nose piece on the hood had a chunk missing. I used aluminum duct tape as a backing, built up the area where the chip was with marine tex (4 coats/ sanding in between), sanded it to match the hood line then peeled off the tape from the back side.
Paint:
Product: Interlux Brightside, color: Blue glo white thinned with interlux 333 brushing liquid
Rustoleum appliance epoxy rattle bomb
After watching a lot of videos, reviews and reading forums I still couldn't decide if I wanted to go the appliance epoxy route or roll and tip method. Hiring a shop was out of the question. I figure I could screw up 3 times and still save $ doing it myself. So I tried both, ha! Even now that I'm done I'm not sure what I would recommend. They both turned out great. Roll and tip definitely turned out waaaay more glossy. Mirror like finish, where the rustoleum appliance epoxy was more of a satin/ semi gloss finish with a tiny bit of orange peel. Roll and tip = 0 orange peel.
I am very confident in the roll and tip paint, don't think it'll ever peel. I used Interlux single stage polyurethane paint thinned out with their "brushing fluid" aka paint thinner. It's a special "slow drying" thinner apparently. Probably spent more than I needed to on it, but this isnt something I wanted to do twice to save $5, so I bought the recommended product. 2 quarts of paint did the whole thing. I also got the Interlux primer - which also gets thinned, rolled and tipped. One word of advice, don't buy more than you need. I noticed that after a few days you get a layer of paint that hardens on the top that you have to scrape off. It always came off in one piece, but I cant imagine this is good. If you get a gallon and only use half, the other half would probably be junk by the end of the year sitting on your shelf.
I painted housed for 4 years (i'm pretty good with a brush) and this was not as easy as I thought it was going to be! The bottom of the hull was a breeze, but the top deck was tough to put on an even layer over edges/ sharp contours. Drips/ sags etc. were a lot harder to control than spraying the appliance paint. Also you need to move fast! If it takes you 20 min to get back to where you started, you'll be left with a nasty line/ seam where it joins up. I got best results jumping from side to side. Roll/tip about 16" at a time, and jump back and forth from side to side of the machine, finishing at the rear. Ensuring each "lap" would blend nicely. This whole process took a looong time. 4 coats bottom, 4 coats top. 20-30 minutes each coat, 20-30 minutes sanding each coat. 8 coats total x 30 min + 6 x 30 min sanding + a couple dozen beer = never wanting to do it again.
Rustoleum epoxy paint went on the nose piece only. More or less just to satisfy my curiosity. Results were excellent, i'm just not a fan of the sheen. It was cheap and re-coat happens after 15 minutes. Start to finish was ~45 minutes then I left it to dry. It says 7 days minimum, but for me it was more like 2-3 weeks before the paint was rock hard. Unlike a lot of "normal" spray paint, this stuff shoots very thin, sagging is practically a non issue, in fact it's almost the opposite. You need to put effort into layering it up, or your finish will be very dull. Spray pattern is small so lots of overlapping is necessary for uniform finish. Get a "gun" handle for the can, helps a lot in keeping the can perpendicular to your work.
Roll and tip Pros:
Super nice finish!!
No overspray
Better product
Cons:
24hr before re-cote
must be sanded between cotes
Must have good brush control
Must move quick!
Pump:
Pump/ impeller was mint. Since this is a shoe string build I'm leaving it as is.
R&D intake grate
Blowsion pump shoe
4" silicone coupler for the nozzle turned up a couple degrees as a hillbilly static trim setup
D-cut stock ride plate
Stubby cone
Engine:
Current:
61x stock
High Speed Industries "wake up kit" consisting of an exhaust stinger, water routing, carb jets/ spring, and stator timing adjustment.
Future:
Port cylinders - possibly this winter... As mentioned, this is a shoe string build. If you've read this far, perhaps you recommend templates for cylinder porting? A few people offer then, i'm just not sure who I want to support yet...
Other idea floating around: Find a complete 62T or 760/ port it and throw it in stock. Or possibly find a rough 62t cheap, bore it to 735, jets, etc. Whatever I end up doing will be in favor of reliability and cost. I like the idea of a healthy stock 760. Mid range power would be great for my style of riding. A 62t would be nice too, 73hp vs 63hp would certainly be noticeable. My stock 2010 SJ was a rocket compared to this thing.
Pipe if I can find one for under a million dollars. In my part of the world this will probably never happen. There's no F'ing way i'm paying more than a few hundred for a used banged up 25 year old hunk of pipe. It's not the only way to pick up a bit of power. Big power yes, but it doesn't need to come first. A pipe is worth what someone is willing to pay, I'm fine with that, and props to the guys who have them and are selling for a nice profit.
In a way, the price of AM pipes is motivating me to build up a decently snappy motor just by playing with timing/jetting/porting/water routing and a little help from an exhaust stinger/sleeve.
- Seat cover and hydro turf on order
- Will be running new old school TAG mx fat bars from my 2005 parts bin. Purchased some 1 1/8 bar glamps off amazon for cheap, drilled/ tapped some 1/4"aluminum flat bar, screwed it all together.
Some pics below, lots more to come!
image2 (2).jpegimage1 (3).jpegimage2 (3).jpegimage0 (5).jpegimage1 (2).jpegimage3.pngIMG_3002.JPGimage0 (3).jpeg
Very nice work. One thing to throw out there, for a very low buck pipe I don't think you can beat the bargain factor of a Wet Jet pipe. I have seen them go for close to $100 even recently in the crazy pricing we've had. You do have to somehow get the cut and weld done to make it fit in a Waveblaster, so if you or someone you know can weld aluminum that's no problem, if you have to pay somebody it could be a deal breaker. I can't tell you how they compare to the higher dollar pipes but I can tell you it's a very noticeable upgrade over stock exhaust.
the wetjet pipe is definitely something to consider. ive ridden superjets with a wetjet pipe and they all ran great. minimal difference in power over like a b pipe. regarding getting engine work done, id recommend paul lehr (LPW) Jr. on the X. i just had a complete 62t engine ported and bored over, case porting and everything. Paul was excellent to deal with, quick responses, and very quick turnaround time. he even met me in person to both pick up and return the engine. he had some work to do a few hours north of me and was able to stop on his way up. i chose him because he is one of the few builders who still actually ride. im currently in the process of putting the engine in my superjet so ill have to report back on how it runs compared to stock.
Ok, been a while since I've updated this. I have been working on other more Canadian winter friendly project. Not very fun working on jet ski's when the garage is 20F and the sun goes down at 5pm. With all the parts on the bench however I'm getting more excited.
Question: Assuming I do a A+ porting job and don't run a cutter up the bore (first go at it, but I am a licensed automotive tech so I at least have that to my credit), how important is it that I hone/ go a bore up after porting? I already know the obvious answer, but I'm looking to hear from people who have stripped it down and put it back as-is. Even the Yamaha superjet manual gives instruction on how to clean rings as preposterous as that seems.
After chamfering the ports can I use some wet sandpaper to clean up instead of running a ball hone through it? I'm not crazy, I got the idea from the Yamaha manual. Initially I as thinking "I will obviously run a ball hone though it at a minimum". After thinking about it i'm wondering if i'd better to leave it if i'm not changing the rings since everything wears in together.
Its's a good running/ good compression engine. Plan is to carefully take it apart, hog out the ports and carefully re-assemble changing northing but gaskets. Thoughts?
I have taken a motor apart, ported it, did nothing but cleaning with nothing more abrasive than scotchbright, no honing, put it back together and had great compression. I don't see any reason why the rings would be any better or worse after disassembling and reassembling than they were when you took it apart, it would completely depend on the condition of the motor when disassembled, and make sure you don't have any burrs obviously. I carefully chamfered my ports and sort of polished the chamfers with fine sand paper to make sure there were no burrs, didn't touch the actual cylinder wall (very careful!)
Personally, assuming the cylinder wall is in good shape, I see no bennefit to ball hone especially if you're not putting in new rings. They can chip the edges of the ports and the can cause the cylinder wall to be less uniform, and any material they take off increases piston to cylinder wall clearance.
$.02 from some random guy on the internet.
If an actual motor builder that knows what they're talking about chimes in, listen to them not me lol. But that is the experience I have with it personally.
Honestly you should have the bore measured with the correct bore gauge and verify that it is within spec before deciding to slap it back together.
Thank you! This is exactly the kind of experience I was hoping to draw from! Your points about the ball hone are exactly why I'm trying to avoid it. Thanks!
I will 100% be measuring all of the tolerances once opened up. Thanks for the input!
My pollen allergies are back which means the lakes should be opening up soon.
Update:
Yesterday I decided after a few pints to paint my pump and reduction nozzle while I was installing my stubby pump cone. Thanks HSI!
Engine:
Bottom end is in beautiful shape. No idea how many hours were on this thing but it looks new. Even the wrist pin bearing in the pistons had literally no sign of wear. The down side: I suspect this thing sat for a long a** time. When peeking though the exhaust ports cylinder wear looked minimal, taken apart however it's obvious this thing had corrosion on the sleeves that got pulled down. Oddly enough I had 147/149 for compression despite scoring. Used a 0.000" micrometer from work to measure the bore and I'm well within spec, hopefully they'll only have to go up one size.
Thanks to Yamanube for the templates and guidance. porting went well, cyls are out at the machine shop getting a fresh bore.
Hull:
Pump reassembled and installed in hull with Blowsion AL pump shoe and oem pump seal. Not as easy as I thought it would be. The dimples on the Blowsion shoe don't quite line up with the actual holes in the hull which was super annoying. Ended up using my Dremel with 1/8" burr to line everything up. Then used a big clamp to squeeze the shoe and pump together so I could line up the pins in the pump to the hull. Worked like a charm.
Still need to drill and tap the shoe for my R&D intake grate. Also will have to grind my brand new intake grate to it will sit properly. If you look closely in the pic you'll see where the "vein" is resting on the hull and the surface where the bolts go is propped up about 3/8". Thinking i'll have to grind the vein down so it sits a little lower.
Also wrapped my seat. Hydroturf standard seat cover in all black with the "carbon fiber" texture material and white stitching. Never seen one before and I think It looks great for a low buck cover. My fingers hurt for 3 days but It turned out pretty good for a first attempt. Lots of pulling and massaging to get the material to stretch.
Great looking ski, beautiful job on the bottom deck!
One word of caution on the WetJet pipe - there is evidently 2 different size ‘headpipes’ (U-shape after manifold, before pipe) and I can absolutely positively guarantee you the larger one will not fit in a B1 hull. I spent quite a bit of time trying to get it to fit in mine & it is not possible without cutting fiberglass. Luckily I purchased it from a well known seller here & I got my $ back but lesson learned!
I may have a thread here about it, I can post pics from home later if you are interested. I’ve heard good things about them but make sure you get one with the smaller head pipe if you decide to go that route. I decided to wait & found a reasonable price FPP mod pipe & love it.
LB
edit - found the thread & some more budget pipe conversation:
LB
I did not know there were two different size headpipes for the wetjet. I did a bunch of research over the winter and all I could find was people either running them in superjets or cutting up their blasters to make them fit. Definitely not interested in cutting up fiberglass - especially since I just wrapped up that portion of the build.
I actually found a Riva Red that is currently in the mail on it's way up. When I started this build my plan was to see how much juice I could squeeze from a stock pipe with some porting/ timing/ exhaust stinger/ water routing and jetting. Then I found a riva pipe for 1/3 the money of the FP. I'm taking some inspiration from @Quinc and his "maxing out a blaster" thread to see what I can make of this unit.
It's turned into a full blown restoration. After dropping the cyl's off at the machine shop I pretty much decided then that an extra $350 on a pipe wouldn't break the build LOL. My wife would argue otherwise, but she'll be happy when we take delivery of her spark/ tow vehicle.
‘I’m just going to spend a couple dollars to refresh this.......” $5K later into a 25 year old ski, I get it!
I’ve ridden a couple of the red piped skis & they seem to Devi at rly be the best of the lower priced options, and Riva still exists so you’ve got support. I’ve not personally worked on one though, keep us posted.
UPS dropped off a couple boxes of HP. Lake still has a good 4” of ice but stoked!
Still waiting for my ht mats I ordered in November... starting to think I’ll have to cut up wife’s yoga mat.
Got bored last night and decided after a few cold ones to polish my seat brackets (pictures beside un-polished). Turned out decent. Yamaha used a ton of stainless on these things, just need a little love to make beautiful. FE426CFE-D7A0-43E5-81E1-288050492AC8.jpeg701969D5-8A68-4C1C-93B4-92C79560BF12.jpeg95F07CE9-B294-4D58-95EC-DFD1F9884A21.jpeg
Got bored last night and decided after a few cold ones to polish my seat brackets (pictures beside un-polished). Turned out decent. Yamaha used a ton of stainless on these things, just need a little love to make beautiful. View attachment 408680View attachment 408681View attachment 408682
You motivated me to put a bit more hp in my B1! Yanked my 701 yesterday....getting a JM781 planted in it today! Emptiness for another hour!20210328_140312.jpg20210328_140333.jpg
Folks,
Glass work:
Paint:
Roll and tip Pros:
Super nice finish!!
No overspray
Better product
Cons:
24hr before re-cote
Must move quick!
Pump:
R&D intake grate
Blowsion pump shoe
Stubby cone
Engine:
Current:
61x stock
Future:
View attachment 404873View attachment 404879View attachment 404881View attachment 404877View attachment 404878View attachment 404882View attachment 404883View attachment 404875
I don't know how to PM because I'm new here, but I also picked up one in similar shape and was thrilled to see a thread of a fellow Ontarian! The build looks real good and if you've got any tips for someone who doesn't know nearly as much yet, I'd appreciate it!
