2lick
Brap!!!
- Limerick, PA
I'm looking for some input...
I was running an 828 in a heavy square nose hull. The setup was tuned great and ran strong where and when I wanted it to hit. I rode it for a few time this year and she ripped and ran perfect hitting hard. I did a direct swap of everything under the hood and in the pump into a ~50 lb lighter and shorter hull (Brawler).
I got about 20 minutes on it yesterday. Something defiantly needs adjusted. Its missing bottom end hit. If I idle at 1/4 throttle and then rip it, it spins up? Trying to just hop it around, it also seems to run out of water in the pump quick and I had to work hard to keep it "hooked up". I only did one full throttle run (cause I fell off did some kart wheels and rung my bell ha). Seemed a bit slower as well. All around this combo has less emmf in the lighter hull but I know its not running right.
My pump setup is a TBM stuffer with a short cone, 10/16 hooker, 85mm exit nozzle.
Any advise where to start playing?
